Anduril 2.0 battery voltage returning?
jslacker
New Castle County, Delaware
I recently purchased my first anduril light a Wurkkos TS25. I have a question about the battery voltage auxiliaries. I understand if you have over 4 volts your auxiliary lights should be purple. However if I go into turbo mode and then turn the light off the auxiliary battery indicator light turns green which leads me to believe it's under 4 volts but if I click on and then off again the auxiliary light indicates that it's over 4 volts purple again. What's going on with this? Is my light malfunctioning, or do I just not understand Anduril?
