Klem
Yes I did kind of wonder whether the real problem was people over tightening the gland, more so than it being due to how many cores the cable has.
If I can add something...
I don't believe you can overtighten a gland, unless it is a plastic one and you break it by jumping over the thread. It's all about compressing the cable to at least what the water pressure will compress it to at the maximum depth you dive. If the water pressure can compress it further than what you've tightened it to then there will be a gap, and water will leak in. How much is enough tightening? to be honest I don't know so I do it up as tight as possible without breaking and back it up like Lucca with Sikaflex.
What I also do is back it up with a second internal compression. I coat the end of the cable with Sikaflex and then tie a cable-tie as tightly as possible. Then coat more Sikaflex over the top of the cable-tie and pull all this black blob hard against the inside of the gland. Then do up the gland. The tie acts as a extra stop against tugging the cable.
One time I made the mistake of forgetting to put the nut on the cable before doing all this and the wand was sealed and dry before I realised. I ended up tying two cable ties in front of the open gland and covering it all with metal epoxy (JB Weld). Thankfully it worked and never leaked but looks very untidy. Don't do what I did and forget to put the nuts on the cable!
