nerdgineer
Icebreak, sorry for the delay replying to your question - busy holidays and all...
After reading Lightchucker's comments above about not finding any reasonable CPAP machines on ebay, I took a look and - son of a gun - he's right, there aren't any on ebay. I don't know why. All I know is that when I looked about last May I think, ebay was lousy with them (mostly Environics Remstar Plus'), maybe 6 or 7 available at any time over the month or so I was looking, selling from low $100's for a somewhat used machine (few hundred hours) through maybe $400 for a new in the wrapper machine. Don't know why they've dried up - maybe it's seasonal - but hopefully they'll show up again. Lots of accessories for cheap as well, back then.
The CPAP has definitely helped me. I don't sleep as well as when I was younger (and skinnier) but much better than I do without it. Most everyone seems to find their own way to tweak the machine for their own preferences.
For me (YMMV), I decided that the residual air in the mask itself needs to be flushed out better than was done by the exhaust port of the mask, so I drilled a few small holes (thick pencil lead sized) at the edge of the face mask pillow to vent the air in the mask itself. That helped. If you want to maintain the back pressure to the machine, you can cover up an area of the factory exhaust port in the mask with tape equivalent to the area of the holes you drilled (very little - maybe 1/8" x 1/8" total equivalent area).
I notice that later model masks include holes in the face mask itself to perform this same function.
For me, another adaptation is to use the humidifying tank (the little water tank) and fill it with MORE water than indicated by by the fill line (almost up to the curvature at the top of the tank). This makes the air moister which I find better.
I put a hook on the headboard so the hose from the machine goes up for a while before it comes down. This makes it easier to move around and makes sure any water which does get into the hose (because I filled it so full) drains back into the machine instead of pooling in the hose.
Those are my adaptations, I'm sure you'll find your own. The best adaptation - as several CPF'ers have stated - is to lose about 30 or 40 lbs and get one's inner throat to shrink in response to the weight loss; but we're all trying to do that, right? /ubbthreads/images/graemlins/smile.gif
Hope this helps you. It's not perfect, but it's better than not having it...
