Flo1
How did it go Damien? All ops normal?
Hi,
I took the lights for a solid dive today and am happy to confirm they performed flawlessly; ~50m dept, ran them solid for 67min at full power. No issues with power levels, piezo button worked perfectly and shed loads of light output.
For reference, the specific capacitor I used was this one - http://jaycar.com.au/productView.asp?ID=RC5360&keywords=rc5360&form=KEYWORD
thanks all for your help!
George:
Question on the Flex. Say I want to run a regular non-momentary switch with this driver. And the switch was going to be placed between the battery and driver. If I program the driver using a momentary switch as instructed, can I get rid of it after I program it and use a regular switch between the battery and driver?
Thanks
Yes, obviously the switch between the battery would act just like plugging in or unplugging the battery power. The momentary switch is only needed to access/configure the menu and to operate the light at various brightness levels etc etc etc.
If all you want is an on/off driver then a power switch in line with the battery will do that.
cheers,
george.
Awesome... Lets see some videos!
Nice video.... but Light- for- me have same videohead with 4x SST-90 !!! big difference from 4x XML . Qecause of HQ sensor in canon you don't have noise (ISO1250) in video tape
After looking again your video I'm almost sure that you lost a lot of light because you don't use reflectors. I think that big part of light is CAUGHT between front lens and aluminium holder of leds. A lot of light can not simply penetrate front glass , which I think works like semi-mirror ( due to air with lower optical density to glass and water with higher optical density ) .
I think that your type of light is good to soften picture and get colour fullness for macro but not penetrate water in distance for few meters.
Try with some wide reflectors or combination spot/wide
...... I'm using an Apem piezo (in prolongated config) to provide on/off and low/med/hi power control.
Kind Regards,
Damien Siviero
Hello Damien,
Can I assume you use a piezo switch from Apem from the PBA series??
And it looks to me that the click and push functions with the H6Flex are working like they should?
Why this question?
I have been trying to use a pushbutton from Apem from the IPR series with a silicon cover, it was perfect and watertight (I can test up to 8 bar) but unfortunately the switch came on by it self at ± 2 bar
Ow Yes, one other thing about the driver, just like George says just put an capacitor over the switch contacts will solve most of the trouble.
I had it even with my dive light with a B2Flex driver in it next to one of my 35 W HID lights, when I switched on that HID light also my LED light switched it self on, just due to EMI interferances.
After putting in the capacitor the problem was over.
Kind Regards,
JosB
.....If it's a silcone push button you're using, is it the pressure pushing down the button that is causing you the auto turn on?
