dmdrewitt
Re: AquaMule and AquaRam 18650 lights
email sent for AquaRam 18650 :thumbsup:
Will this battery pak host a PD head?
Sent from my GT-N5110 using Tapatalk 2
Head OD is 1 3/8". Light is 5 3/8" long. Battery tube is 1" OD.What is the head outer diameter?
PSM: we need a beamshot when you get it
eala
Guys these Aqua lights are something special. Try and get yourself one if you can.
They have a rock solid, indestructible feel about them just like the old 27LT and the beams are just perfect. The Mule has an amazingly wide angle of flood.
The U/I is pretty much perfect too and I haven't even started playing with the available driver customizations! I find it easier to move from level to level than a clicky U/I.
I'll try and find time and the words to write up a semi decent review at some stage but there are others here that are much better at such things.
One thing that I should point out is that the photo of the Mule head Don has posted above is obviously his development light as the production Mule is perfect under the lens with no scratches or re-soldering.
Don. For the benefit of all.
Since the primary usage environment of this light is under water, in your opinion, will this light be suitable for out of water usage?
FWIW Ben, I ran the Mule in my hand, for a walk last night, at full power for over an hour and it didn't get uncomfortably hot at all.
