Using 3mm SMJ BP Drop-in for Solitaire, Miniminimag and Minimag1AAA
Hi, all.
Just a quick post about this cool bi-pin dropin made by ArcMania. It is probably a very well known mod part for Solitaire, but I also discovered that it works just as well in miniminimag or the minimag 1AAA.
A very brief intro, this 3mm SMJ bi-pin dropin is rather easy to use in modding the solitaire. The best part is one doesn't even have to drill out the reflector of the solitaire(which could be a pain in the butt and needs practice to get it erfect)
Candlemode for the BP dropin with Soli.
Another picture of the soli in action.
The only sad part about the easy drop-in is it will not allow the bezel of the soli to screw in all the way, which leave a little gap in between. I guess it is just not possible to have the cake and eat it too...
A short distance beamshot of the modded soli.
top pix: SMJ BP dropin + Soli
bottom pix: ARC-P
From the pictures, it looks the soli with the BP drop-in is outputting similar amount of light to ARC-P, but the hotspot of the 3mm SMJ is probably brighter.
I think the best kept secret about this little wonder is the fact that it works really well with the Minimag 1AAA or miniminimag. So far, AFAIK, there is no known product that is designed for this configuration.
Here is a set of pix that compares 3mm SMJ BP drop-in to 5mm SMJ in minimag 2AA...
Top pix: Solitaire + 3mm SMJ BP drop-in
Second pix from top: Minimag 1AAA + 3mm SMJ BP drop-in
Third pix from top: Miniminimag 1AA + 3mm SMJ BP drop-in
Bottom pix: 5MM SMJ + Minimag 2AA
Measuring the hotspot lux reading 1m from the flashlight:
5mm SMJ + Minimag 2AA 414 lux
3mm SMJ bi-pin drop-in + minimag 1AA 554 lux
3mm SMJ bi-pin drop-in + minimag 1AAA 142 lux
3mm SMJ bi-pin drop-in in soli 99 lux
ARC-P 67 lux
The 3mm SMJ bi-pin dropin with Minimag 1AA actually outshines the 5mm SMJ in 2AA minimag. I think the main reason is because it has a smaller emitting pad which allows a more intense hotspot to form. It may not be perfectly regulated like some aftermarket product, but enough to make one appreciate its value. Much to thank is ArcMania to make this avialible to us.
