ASTROLUX WP3 LEP 562lm 2645m 21700 Flashlight - Shipped
freeme
ASTROLUX WP3 Group Buy
LEP 562lm 2645m
21700 Rechargeable Flashlight
Group Buy Price: $179.99 (usual $306.00)
Freeme's Coupon: Reply on this thread
Can't wait for our reply?
Special Price: $189.99 (usual $306.00)
Freeme's Coupon: BGAWP3
Description:Astrolux® WP3 LEP light source has high energy density, and then passes through a special lens reflection system to form a dazzling light column. High and low brightness modes are adjustable, simple and practical. WP3 LEP search light throwing distance up to 2.6 kilometers! , Luminous flux 562 lumens, light intensity reaches 1750000 candela, comes with one 21700 rechargeable lithium ion battery, high-quality drive circuit with temperature control, constant current drive and ensure that the flashlight will not overheat. It is designed for special lighting.Flashlight Specifications:
NameAstrolux® WP3 2645m Long Shoot LEP Flashlight
MaterialAluminum alloy, black hard anodized surface
Reflective systemAcrylic lens
Light sourceSpecial LEP module, wavelength 450-700nm, lifespan about 10,000 hours
Distance2645 Meters
Intensity1,750,000CD
ModeLow - High - Strobe
Lumens95lm - 562lm - 562lm
Battery1x 21700 or 1x 26650 li-ion rechargeable battery (21700 Included)
Impact Resistence1.5m
WaterproofIPX6
SwitchBode side, 50,000 press life
LensDouble coated tempered glass lens
WeightAbout 330g (without battery)
Size (±0.5mm)
(head diameter) 59.5mm, (body diameter) 34.5mm, (length) 187mm​
Battery Specifications
Item​
Astrolux® E2145 21700 Battery
Typical Capacity​
4530mAh​
Minimum capacity​
4500mAh​
Nominal voltage​
3.7V​
End-of-discharge Voltage​
3.00 V​
Max Discharging Current​
28A
Weight​
Approx:70±2g​
Operating temperature​
Charging:0℃~45℃Discharging:-20℃~60℃​
Storage temperature​
-5℃~35℃​
Storage Humidity​
≤75% RH​
Size, Diameter22±0.5mm
Size, Length71±0.6mm
Net weight
70±2g​
Features: - High efficiency constant current drive circuit, no noise and no PWM- Temperature control protection: when the flashlight temperature is too high, the flashlight will automatically reduce the brightness to prevent overheating- Reverse polarity protection- Low voltage prompt function- Battery over discharge protection
Package Included: 1 x Astrolux® WP3 LEP Flashlight1 x Astrolux® 4500mAh 28A 21700 Battery
2 x Spare waterproof O-rings1x 21700 to 26650 battery conversion tube1 x Lanyard
1 x User Manual
TheDCC
PNW
LEP 562lm 2645m
Group Buy Price: $169.99 (usual $306.00)
Distance2645 Meters
WaterproofIPX6
Size (±0.5mm)
Item​
Typical Capacity​
4530mAh​
Minimum capacity​
4500mAh​
Nominal voltage​
3.7V​
3.00 V​
28A
Weight​
Approx:70±2g​
-5℃~35℃​
Storage Humidity​
≤75% RH​
Net weight
70±2g​
1 x User Manual
Interested if still available
TheDCC
PNW
Banggood has decided not to take in any preorder until they have adequate supply for it.
Thanks for the heads up. Can I assume you will be informed and posting here on CPF when that happens?
lumen aeternum
Interested... do the earlier models have a smaller head size, better for mounting on a rifle? Can you get a red or green filter ? What is the color temperature?
freeme
This is ASTROLUX WP1 LEP has a much smaller head size but it is out of stock now.
