Baroutologos's Handcrafted - Rechargeable LED Hurricane Lanterns
Baroutologos
In continuance of the reflector /shade issue,
this is how is finilized a less reflective approach.
and
more photos at http://s1358.photobucket.com/user/baroutologos/slideshow/12-2-2016
The particular reflector was sand blasted both sides. Coarse blasting on the exterior, polishing blasting on the interior. Both sides laquered. It provides a gentle reflecting surface even spreading the reflected light.
cheers,
Barou
Baroutologos
Hello,
its have been some time since my last post in here regarding my lantern's tech. Although all time i rearrange things and make edition upon edition of every single aspect in lantern making, past easter i made an interesting upgrade.
I was thinking about making an alkaline batteries run, low power (max 1 watt) led lantern. I was in the process of visualizing the circuitry and other things too, and i realized screwed bottom style lid that i currently employ in 18650 cells (that are inserted once and forget them) will be a great setback to an alkaline cell lantern that needs to open the lid and secure it again in an instance.
An image equals a thousand words..
video: https://youtu.be/EtKaW5tyrYo
cheers,
Barou
Baroutologos
just before my summer holidays start, i had to make two lanterns. One for me and one for an uncle of mine.
in this post i will present my lantern to all fellow lantern enthusiasts.
First consideration was the chassis. My very first lantern as a child was a BAT 158. I could not go otherwise, let aside it is the one of the smaller chassis around.
Also, i had the luck to outbid a crowd or better to give a lot of money to get a bunch of original, embossed "BAT is the Brightest Made in Germany" small globes that i have not seen before in my long engagement in lantern making.
Then i had to have an original reflector. I got one. last i had to choose the finishing.. I was tortured in dilemma between a bare metal lacquered finish and sprayed red alkyd paint. finally i went with the alkyd paint finish. My grandfather used to paint with alkyd paint, now as i sniff the peculiar smell of the alkyd paint, memories come to mind. Good ones.
Bottom cover is of new style instantaneous opens/closes if you you learn how with a small screw driver.
I wont say much more. Comments are yours..
Cheers,
Barou
ps: i used an HVLP for spraying the alkyd. It produced an almost complete orange peel look. Its way too good to me.
Baroutologos
It has been some time since last post. One thing i want to show to Baroutologos lantern owners is that all L models and K models can work with a USB to 5.5mm 2.1mm cable, assuming their charger is of good quality and current regulated.
I use every night and day one of my lanterns (BAT 158 red color, L model) and i was sick of using the bulky (but fast) charger. So, i got a cheap a USB to male 5.5mm 2.1mm cable and i have one charger and i share it between my adroid and my lantern. I also use this cable for charging up the lantern from a car USB/ mains charger.
Small things that keep me happy i guess.
Cheers to all,
Barou
y4mUDwVM2hBcpHQFMm6YHu_0RKZ9cBFW3DUHY1FREyxD57ld0BY675G95Sx82kt7QL2n2H5XjDEQy6-31GmvzgYM6PYAI8C9-Ln3WQ8TTGjF0cLd_6oiwNJho-Om5xhh8ILh6n-0WeUR1BQ4SAbfwEDZy3dLv5sV9BCbO6WusAtGOMPh5Q5mLyVIUfeFufeNZCpdhiz7pt_B6bo7fk_L1IZFw
y4mXqMK810EZNhwuIY4f6RdtScRwl3ZMCywwcfYGb4frGj7-_1uac4TIP5-Y1aqgDnE7KszqPCvP8droQBAAinNSr-H4qjN4JzjZRZizbTgxRQkZWN6DOhnoojH5qBMyVLhVugxfqIb__SAyQEs52jzDnn26zdfY9pq7ND0rwd8XMtWeCrD7lq0Kq6fLyDjWiMNzJfIR5_6rgEBt_MDQPhxsA
y4mo_Xxhy-Zepr2TlaS58FM5L1T-OgHFeEjsLyKITWlyfV3KODM1U_pvCTKPm8m_GCBhmdKV50-6s3fharSe2sUc2WrFmrPcbSa2xnAvZQ3-qtZZrl0vrqy-BuIGaH2uFxrVaUesK1xOfHpeIoTWujIqpPj6Wt-O2NYFEjrCGgj7wAvkhsbo55A7iZtC13ck3hRpYMafB6gYe9Nf5d0v0eYRw
thermal guy
ny
I'm just seeing these for the first time! They look awesome and for what your getting they seem very well priced.
Baroutologos
Hello,
It should be posted also here. campaign is up and running.
Feel free to have to visit and support.
Cheers,
Barou
