StandardBattery
Hmm. Most are saying 9A draw for Turbo-S, but of course this would vary with cell Voltage, is 7A what you measured?
You are right though that with their 2S2P configuration that is only 4.5A per stack. That is well within the MJ1 and GA cell capability, even protected versions. Seems like early reviewers and Olight are over stating battery requirements, unless you want to run the light on just 2 batteries. In fact it's sub optimal for the 30Q which operates better (more capacity) at 10A than 5A discharge. Of course maybe the voltage drop on the general cells does not allow the light to reach full Turbo and the driver limits the max current it will draw on each level so it can't make up for the drop. Still seems like if the design allowed for between 7-9A draw per stack then it could maintain turbo a lot longer. This would be within spec for the high-drain batteries.
Seems to be some conflicting/missing info on the power/battery requirements. If it is using only a max of say 5A per stack, then look for a clone that ups that to 10A per stack. Battery contacts might be a bit triky on that for a clone light.
