My initial report. The BMX80 wins against the X80 in brightness and runtime. I'm running the BMX80 in the 8AX.
It is effective to 50' very good hotspot and good sidespill.
With the X80 aimed at a point on the wall I turned the BMX80 on the same point.
Result - I can't make out the X80 except in the ring of cree.
Batteries used are made up of these
Sub-C cells and the B90 Harness wrapped in Kapton Tape.
I got 80 minutes runtime on the X80
At the battery 2.2A at 4v forward
And at the end 1.2A at 2.1v
I got 4 hours high output on the BMX80. Its still running and I need to go to bed soon.
I'm thinking we have a buck boost driver here with a max Amp in.
It got rather hot then dropped in output.
At the battery its pulling 920ma on a fresh battery with 4v
And 130ma on a battery run for 5 hours down to 2.5v under load
Luxmeter readings will follow with beamshots.
I'd like to take lux readings on the BMX80, X80, X80-LED, Downboy917 w/ USVOI in Aleph1, and a Surefire 6P
I chose the 6P because most of us know what it looks like.
And the Aleph1 w/DB917 SSC because its similar in output to the BMX80 and uses the same reflector as my X80-LED (McR-27)
Any thoughts?
