Re: BessieBenny's Budget LED (DX/KD etc) Flashlights Review Roundup (Part 10)
Always do, it won't load.Use https://
Just loaded for me using https
well, some pics would be usefull...
1st. are yuo sure the switch is culprit..to check pout the batts in and link the batt butt to the body butt. LOL
2nd...check if the switch retaining ring inside the tailcap is properly tight (for a mystereriou reason whne you tighten the tailcap TOO much it usually loosens)
do you see two circular recesses on the switch retaining ring? use nedle nose liers to screw unscrew them
3rd do you have a multimeter or any other way (some wire battery and a bulb) to check if the switch itself is the culprit? does it always turs on or off?
4th if you have a soldering iron or access to one, shop for switches at the flashlight DIY section of Kaidomain.com and dealextreme.com
(sorry for assuming zero flashlight tinkering knowledge...)
good luck, kostas
Are you saying that the top head will not unscrew? If so, you may need a little heat, or freeze it. Then depending on your budget, you can order a solarforce R2 drop-in. Others are offered here on the forums.
