Just received my new
UltraFire U4-MCU from DX.
Initially it didn't work (a common DX problem it seems) but after a bit of fiddling it fired up and now works perfectly and gives an excellent beam. The DX envelope and box had been ripped open and then crudely taped up again, probably by some impatient Customs inspector, and the AAA battery holder was missing one of its vital spring connectors, so it's now useless but that's OK, I wasn't really planning on using it anyway. I wouldn't be surprised if my spring is lying on the floor somewhere in the Customs office.
However, it's a very nicely made light, but the factory assembly is not very thorough, so the first step with all of these Chinese lights seems to be to unscrew everything, clean off excess lube, clean all screw threads, then reassemble everything carefully. A bit of a nuisance, but not a major problem considering the cheap price.
In my case, the problem was with the LED drop-in module. The reflector is machined out of an aluminium cylinder and the driver and LED are pressed into the base. There is a brass rivet through the black plastic base that serves as the positive contact. I think something in the base wasn't making contact because when I pressed firmly on the base, there was a little "click" and the base moved down very slightly and that solved the problem.
I would like to disassemble the module to check that everything is OK inside, but I can't see how to, apart from levering the plastic plug out with a sharp point which could easily destroy it, so I'm wondering if anyone else has encountered one of these modules and is there a way to pull it apart without damaging it that I'm missing?
