best HID-style headlights?
BugLightGeek
St Louis
I'm wondering...what is the best/brightest HID style 9007 headlights?
I'm not looking for an actual HID ballast or lamp, just the normal 9007 style replacement bulbs for my car.
I also see the various lamps with different ratings:
-8500K
-6500K
What do these mean and which is brighter?
My goal here is to get something with the HID tint to it as cheaply as possible /ubbthreads/images/graemlins/broke.gif /ubbthreads/images/graemlins/grin.gif
MaxaBaker
South Jersey
I don't know what exact bulb would be brighter, but I can tell you what the k ratings are.
The "k" ratings (ddegrees kelvin) are the color temperature of the bulb. The sun's color temperature is somwhere from 5600-6200k. The higher the color temperature, the more blue to purple the color is (with the sun being almost perfectly white. it's like the middle of the road). The lower you go, the more yellow to orange to red the bulb "k", or color temperature will be.
The 6500k bulb would be slightly bluish giving you a very good HID tint where as the 8500k bulb would be more purplish tinted (I wouldn't suggest going over 9000k if you're putting it in your car). They go all the way up to something like 16000k which is a deep purple and looks very bad for automotive use IMHO.
Both should be about the same brightness I think.
BugLightGeek
St Louis
ok...good to know.
I definately want something that's 6500K then.
So, what are some suggestions for good & bright headlight bulbs? /ubbthreads/images/graemlins/poke2.gif
lotsalumens
NYC, USA
If you look at the specs of the bulbs you'll see that the actual lumen outptut goes down as collor temp goes up. Those purple bulbs will not be quite as bright as a more whitish bulb around 49k. It's a tradeoff.
cfb
Penguin
Diamond Bar, California
Sylvania Silverstars seem to be pretty good. I use them in my Pathfinder, the light doesn't look much whiter/brighter from the driver's point of view.. but it DOES look whiter/cleaner from the outside
MaxaBaker
South Jersey
SilverStars are cheap and are probably better than the ones plastered all over Ebay. You can get them from PepBoys for $25 /ubbthreads/images/graemlins/smile.gif (for 1 set)
java_man
those inxepensive ones with names like "hyper-white HID plasma-blue arc"
are not really HID at all, just tinted halgen bulbs /ubbthreads/images/graemlins/thumbsdown.gif
dont waste your money on them
Sway
North Carolina
BLG,
You can't drop a 2DS HID into a standard Halogen automotive reflector and use it on the road a retro fit requires a cut off shield for the upper half of the beam to keep from blinding on coming traffic. Check out some of the car HID forums like this for more information.
Later
kelly
Draco_Americanus
Michigan
The main reason the normal halogen "hid" knock offs are not as bright is because the blue coating filters out some of the light.
I would get the silver stars, they are street legal and are a bit better in color.
BugLightGeek
St Louis
Yeah, I guess I should probably get some Silverstars.
I was really hoping for a better alternative that would more closely imitate HID without actually spending the $$$.
I also found that Sylvania makes turning indicator bulbs that have a blue tint when unlit and amber when signaling. Those sound like they would look sweet. Especially since my car is a lighter shade of blue already.
In fact, I built up a DD Lux III Mag Mod with a Mag body the same color as my car! /ubbthreads/images/graemlins/grinser2.gif
enLIGHTenment
Ottawa, Canada
[ QUOTE ]
[/ QUOTE ]
Isn't that a bit like pasting fake a 'R-Type' sticker on your car?
java_man
be careful with these over wattage bulbs....besides being illegal to use on the road, they can melt the plastic around the lamp, melt the wire insulation and burn up the headlamp relay...auto electrical systems are engineered very very tightly to save money, doubling the amp load on a circuit is almost guaranteed trouble /ubbthreads/images/graemlins/jpshakehead.gif
BugLightGeek
St Louis
Yeah, I hear you on doubling the amp load /ubbthreads/images/graemlins/eek.gif
I will probably end up with SilverStars.
Now, I just need to find the SilverStar upgrade bulb for my turn indicators as well! /ubbthreads/images/graemlins/cool.gif
Waterfish
New York
Sylvania Silverstars blow pretty quick. They arent rated for two many hours to begin with.
If you want the maximum light output without increased wattage from so called "HID xenon superbrite bulbs", you should consider Silverstars from Osram, sylvania's parent company.
Osram silverstars are generally the same, but dont have the blue/purple coating that the sylvania ones have. You wont get that blue effect, but you also dont have to worry about the bulbs blowing early.
Sylvania is well aware of this, that's why they dont rate their usage time for very long. On the upside they do look nicer/whiter.
You might have trouble finding Osram Silverstars. I winded up ordering mine from the UK, then eventually switching over to HIDs.
When your silverstars do blow out after several months though, you might have warranty to get yourself another set.
-Jerry
