travelinman
Taketheactive....I guess I'm not understanding what you mean by "missed termination". How could the BC900/700 not terminate when the LED indicator showed "full" or indicate the number of ma when using the "test" function?
I've been charging NiMH cells for over 2 years now on the BC charger and all indications including the anecdotal reports of longer run times, more transmission time (which is the real test as transmitting on a 5 watt handheld is heavy draw ~2A) on the same cells that are now 2 years old.
I'll do the tests you describe as soon as my roof is on, however my setup may alter the results.
I have a large finned aluminum heatsink (4" wide, X 1.5" deep X 7 or 8" long) that the charger rests on, with a 12v comp. power supply fan running at 1/2 speed on 6 or 7 volts blowing both above and below the charger. I also have an aluminum sheet bent to form an air deflector so that all the air goes directly toward the charger. There is NO overheating of any kind. As a matter of fact the cells are still cool to touch even when I have, on rare occasion charged at .5C.
