Alaric Darconville
Our eyes excel at viewing the visible light spectrum. Stop and think about what the "visible light spectrum" is and you'll discover why IR and UV shouldn't come into play here.LEDs excel at visible light spectrum. This means they're not so good at telling the difference between oil and water, ice and water, and are also typically pathetic at penetrating bad weather, and tend to rainbow at the higher lumens.
Any white light, or light that also goes into the IR and UV portions of the spectrum, will rainbow under the right conditions.
Ultimately, the most important characteristic of a road-illumination device: Intensity.
Filters don't change light from one part of the spectrum to another. They merely only allow a portion of the light to pass through.It can almost-kinda be solved with advanced filters that change some of the spectrum into infrared and UV, the waves that give incandescent and HID such advantage.
Also, why would we need to filter LEDs? There's such a thing as UV and IR LEDs...
