Just a few quick comments. Regarding why AW's cells are preferred by many on these forums over other Chinese cells, it has a lot to do with experience. Some of us that have used both AW's and the others over the past 5-6 years, like myself, have seen a marked difference. AW's cells nearly always have more consistency from cell to cell than the other brands, which is critical for series applications. This doesn't mean that you will never get a bad cell from AW, but I never have. This is something I can't say about cells from other distributors, such as xxxxxFire. Also, new cells from AW nearly always have better voltage retention than the others. This is a sign that the cells that AW provides are newer. Keep in mind that unlike NiCd/NiMH cells, all forms of Li-Ion cells start to degrade significantly, from the day they are manufactured, whether they are used or not.
Another factor that those fairly new to using Li-Ion cells may not be aware of, is that just because a new cell performs well, doesn't mean that it will perform as well 10, 20, or 50 cycles later. In my experience, AW's cells outperform other distributor's in the long run. They retain usable capacity for more cycles, and retain their consistancy from cell to cell, far better than any of the others. That doesn't mean that you won't come across a good sample from the other distributors once in a while, but this very inconsistency is a problem. You can never be as sure, what you're going to get.
As I have mentioned in other threads over the years, I don't know how it is, that AW manages to provide better cells, but I suspect that he has a close relationship with one or more of the 3(?) Chinese Li-Ion cell manufacturers. This possibly allows him to get "first pick" among the surplus cells manufacturer's offer. This no doubt would cost him more, and the additional cost would obviously have to be reflected in the price of his cells.
As for determining the estimated capacity of LiCo Li-Ion cells by measuring the OC voltage of the cell, the various charts/tables that are commonly used, were never intended to be an absolute means of estimating capacity. Also, years ago, when most all Li-Ion cells on these forums were LiCo, it was understood even then, that voltage readings below 3.80 Volts were not as accurate, due to differences in the actual composition of cells from different manufacturer's. Jason's findings seem to reflect this.
Dave
