2100
. I do have a question for you Taurasmark the HID you have is it the 35W flashlight style if so have you had the ballast out of it or would you be willing to take it out and measure the ballast lenth minus the bulb. If you need help I can help you its held in with 3 screws under the reflector. The reason is there are replacements ballast for these lights 3 different sizes some of us are trying to find out what each size is rated at, but for some reason we all seem to have the same size ballast so far.
Be very careful when taking out the ballast. As it will slide out from the battery compartment hole at the back of the torchlight, the ballast body will slide out first, and when that part ends it will drop out, BUT THE BULB WILL STILL BE WITHIN THE CONFINES OF THE FLASHLIGHT TUBE. So what happens is the ballast body angles and drop out, the bulb hits the tube, and the bottom part of the quartz bulb support will break.
Somebody pls ask me how I know that. LOL! Luckily its the 50W ballast, not the brand new 65W ballast. I have a 65W coming in!
Also be careful when the metal washer is screwed out. You can remove the battery by sliding out, you'll be ready for that probably. But then you will not be ready for the falling out ballast.
2nd bummer!
