Hi Guys, I'm new to this forum. I read this thread and would like to offer my findings on IR illumination...Dead cheap /ubbthreads/images/graemlins/wink.gif
Like many here, I've messed with IR Leds etc, there are only a few that can cut it, the best I found were some german multi-chip beasties, which are not bad, but about £10 each, so these were discounted.
I have 2 russian nightsights, a 1st and 2nd gen, the later cost about £2K I believe, it's 14 inches long with the 'Big' zoom lense & light hood. I have a 6 Volt lantern type lamp, which has good power, (note.. modded for sealed lead acid batt) I researched certain dedicated IR filters, obtaining some samples of the Lee IR 87 filters, light transmission above 730nm etc. These worked ok with my 2D mag-lite. Noting that all things that appear black are not always, I have a 'black' glass ashtray, that is indeed 'Not' black its actually dark red. It actually worked as a crude IR filter when hitting it with lots of light, the drawback being the glass is unnecesarily too thick and heavy. Baring these thoughts in mind, I applied the same to plastics. I obtained some ICI Persex, black of course, this also is indeed dark red. I cut a new lense for the 6V torch, replacing the original. An optical comparison between the Lee IR filter and the Perspex one appeared to have the same dull red glow etc. Tests with the Night sight were good, I could illuminate stuff at about 80 metres, (limited by the distance I could get from my garden). This same cheapy method should work for video cams. Perspex looks usefull..
Steve
