Re: Reflector cleaning HELP!
Problem solved! I had a shower so my skin was soft adn used my little finger and some soap to gently wipe the reflector. I then used CIF bathroom and shower cleaner and sprayed that into it and gently washed that in. rinsed it under a very fine, clean flow of water and working circular around the reflector to the bottom. the clean flow of water collected the droplets as it went and meant i had a clean dry reflector. it was a little damp in areas so I put it back in the light with the cap over the top but loose so no dust got in and water vapour got out
