KillerJupe
- Joined
- Sep 27, 2015
- Messages
- 3
Hi,
I study insects and often collect them at night.
A good headlamp is vital to my work.
After screwing around w/ off the shelf lamps i was always disatisfied w/ limited battery life, brightness or color choice.
I decided to make my own headlamp and used this 7 up luxeon as the primary light. http://www.luxeonstar.com/white-5028k-7-led-40mm-round-coolbase-assembly-1400lm
I used a 700mah dimmable led driver: http://www.luxeonstar.com/700ma-external-dimming-flexblock-driver
I enclosed it all in a small project bock which i clip to my hip and power it off a 3cell 3000mah LiPo.
This way I have the power to run all night while getting the color and light output i need.
The down side to my LED choice is, its HOT and my little chipset heatsink needs a fan.
I've head Cree LED's are a lot cooler per lumen.
I am having trouble finding a sutible Cree LED setup.
I need about ~1500lm in neutral to cool white.
I would prefer to make a swap as cheap as possible.
Thanks,
D
Thanks,
D
