Missed this one Stephen
I responded, showing you that a square meter of plants exposed to sunlight receive roughly the same amount of light from the range of 400nm-500nm and therefore I did not believe your statement to be true. I still don't.
First, I use light demanding corals as an analogy towards your lettuce scenario because both the symbiotic algae in shallow water SPS corals and vegetative plants have a similiar demand for blue light.
Next, I really don't care about matching the spectral energy the sun emits because you simply cannot match the broad spectrum response of the sun with a solid state light source and expect the same results on plants by only focusing on specific spectral weighting. It's billiard ball physics and far too simplistic given the additional spectral characteristics of the sun -vs- any number of LEDs. It's even problematic with artificial light sources given that a metal halide with a measured peak spectral weighting doesn't translate into a LED light source with the same measurement. The halide source typically has a much narrower emission range in the 440-460range, and if you use the same peak spectral energy flux measurement with any given LEDs the results will be way too much energy. At present plasmas are the only known artificial light source I'm aware of that can kind of mimmick the broad spectral weighting of the sun. For that matter the energy of the equatorial sun on plants is likely mostly wasted, but it's other factors including infra-red for leaf heating, and possibly blocking pigments having a much greater factor in this that are totally skewed with solid state light sources.
Plants have several mechanisms allowing them respond to changing lighting conditions. Many plants utilize some form of Heliotropism that allow the leaves to follow the path of the sun.
See above. This same 'mechanism also robs the plant of energy. One thing I've noted with artificial light sources, and possibly you have as well, is that high efficiency T5/T8 do a much better job with vegetative growth than corresponding halides or mass market high density LED fixtures likely because the light source is distributed along a far larger area. It's a guess, but that same issue holds true on salt water tanks.
They are lost to various mechanisms. If you concentrate the output of your fixture to relatively small areas then you are simply reducing effectiveness of your source
Never said I disagree. I also recall that every fixture I've advised people to build utilizes long bars of aluminum and not high density clusters aka Chinese Ebay lights so I'm not sure why you accuse me of being in the Ebay crowd. However, LED optics aren't true point sources like the sun is, nor do they behave like typical halide reflectors.
From my point of view, they promote the use of concentrating lenses simply so that can then produce site specific hyper inflated PPF readings
Exactly, and to promote their claims they use non-standard PAR meters which have no basis for either fixed calibration, nor relevant spectral weighting other than a purple filter over a cheap photo sensor. They spit a number out, and the higher better, right?
However, the collimating effect I noticed with plants had more to do than simply law of squares. Plants have not adopted biologically to highly intense blue light sources a few feet away emitting a narrow band of 455nm energy. Spread out fluorescent tubes have a closer analogy to a lightly overcast sky, which may be why certain plants respond so well to this type of light source more efficiently that halides (with blue light).
Further, you should be lighting not just the top of the leaf surface but the bottom and sides as well. Hell, you should even be allocating a small portion to any green areas on the stems.
Agree as well. I recall back in the early 90's large scale tests done on various crops with reflective materials placed underneath the plants to produce different growth patterns, and the results ranged from minor to major depending on the plant and color. This was done over acres of land and not single plants, so the results were quite conclusive. As I recall plants the required a higher weighting of red light responded better than vegetative, but there were mixed results on both sides.
I'm not sure what this has to do with my original statement as we were referencing 300 source watts of Royal Blue XT-E per square meter
Since it's not the same type of plant the analogy will be nothing but prone to arguement, however I was working with a surface area that translated into far less than 300 watts per sq meter of LED light and an organism that thrives under 1200watt halides. However, I stand my my statement that 300watts per^2 meter of XT-E blue light focused into that area exceeds typical published requirement for horticulture, so your numbers are up for speculation and not mine. I've killed plants with far less. We also need to stop focusing on a single band of blue energy and possibly discuss broadening this. Just because LED makers want to sell us LED's based on specific bins doesn't mean lettuce only responds to a specific one.
Red light...maybe. Different physics and efficiency factors apply to all. The really irritating thing is usually I'm the one being jumped about being way to over-zealous with blue light requirements and now I'm getting it from the other direction
Trying to light a greenhouse with halides that produce the equivelant of 300watts of XT-E emitted light though would likely require your own power plant.
As for Cree in general, I'd appreciate that if any metric they use be applied to all manufacturers on an equal footing, and right now we know it's not. Nothing, and I mean NOTHING published by Cree (Or Bridgelux or Phillips, etc) is going to be presented without being filtered via their marketing dept first. These companies are governed by shareholders, not scientists. I noticed with the spectrometer you sent me that published numbers from Cree and Bridgelux for example did not translate into their actual products in relative testing.Cree of course will say 'test it this way' while Bridgelux will say 'test it this way' according to their benefit.
