I am having a hard time agreeing with this information.
a) Designed for 350 vs 700
- Normally, an LED designed for 700ma operation will be more efficient at 350m.
- I may be entirely wrong, and one die may be different than the other technically, but this is not the reason IMHO.
I didnt want to go into details but it seems i should. Also i will stick with white color because i have much more experience with white.
Luxeon K2 TTFC LXK2-PWC4-0200 (ignore the recall problem, just focus on the numbers) is marketed at with 200lm@1A (Min) and 170lm@700mA (Typ). If you dig in the datasheet you also find the flux at 350mA which is 95lm.
Cree X-RE Q5 is marketed with 107lm@350mA (Min).
So i say again, the best led is the one the has the highest flux at the lowest current (if the voltage is the same). Its better because of the heat issue.
Ic) Binning vs Marketing
- While your general concept might have some merit, that binning is a factor in marketing, it is not "just marketing"
- While it is quite difficult to stand around and shine an LED on the wall and exactly tell the bin, I know plenty of people that can easily identify which "similar" LED is brighter, has a nicer beam, and has a more pleasant color "for their eyes".
- I suggest you take the time to build or buy a few flashlights and go for a walk through the woods, or try cooking a steak by the light of an LED flashlight before you decide that color temperature and binning are not useful and significant.
Binning is more about the problems with the way the leds are produced then its with marketing. The same problem have cpus. Ofcourse u need to know the bin of the each led you compare.
d) The web link
- Surely you do not believe the numbers from an on-line retailer as your main source of information about LEDs ?
Actually i take all the numbers with a grain of salt. First because the industry doesnt have (yet) standards for measuring led performance. Second it seems to me that all the big producers try to confuse you with their datasheets. Some give the numbers as typical values, others minium, others maximum.
Third, is no use comparing two leds based on their luminous flux if the current at which was obtained is not the same.
And forth, considering online shops are the most used way to get our hands on leds there must be a degree of trust in what they say. Otherwise where can you buy them from? No official distributor will look at a small customer.
e) Lumens per die
- The "typical" results today from the major producers are all in the range of 100 Lumens per 1 x 1 mm die for similar packages and white color temps.
- After that, it is a matter of binning, packaging, and marketing.
- I will admit that some suppliers are more active in promoting their products on internet forums than others through stealth memberships.
Actually i admit that considering the lack of standards and the fact that buying leds in small qtys is sort of a lottery any brand name will do. Its more a factor of brand awarness then its performance.
