ElectronGuru
Re: Custom Surefire® Lego Parts M|C|Z|P|G: Extenders, Bezels, Bodies, Tailcaps
leukos,
ekengle,
Bob96,
Orders shipped!
:thanks:
leukos,
ekengle,
Bob96,
Orders shipped!
:thanks:
Sorry - My PM's arent showing up as sent.
I have a G2 and would like to upgrade it to one of your Defender heads with a Malkoff drop-in. Is this body/head/drop-in combo possible?
Possibly I'd be best suited by purchasing yoour "Cren-Bezel" for a G2?
How much does a metal bezel help, really?
Hi Justin,
Both PMs received!
The main issue with bezels and bezel ring additions to G2's is not so much the threads (fitting them together) but how much power you want to run through the LED setup. For Nitrolon bezel + Nitrolon body, the M60L (which we can provide) is about the max you want to go for continuous reliable uses. If this is enough, adding a cren ring to your existing G2 bezel should work fine.
If you want to go brighter, like an M30, a metal bezel will let more of the heat from the more powerful module, escape. In this case, a full Defender bezel is the way to go.
Dan
-Is the M60L is brighter than the stock G2 LED?
-My G2 has a screw-on metal head, will that host the M30 or a brighter drop in? Or does this drop-in require a larger diameter head?
A metal body is the best way to go and in the cases of 2+ amp configurations, a must.
Hello, Any C3 or M4 HA's available??
