A review of the summarized options (open for corrections, and editing).
Daytime comparisons of these lights would be fantastic but I doubt anyone with have two of these to compare. So we will take pics of any of these in daytime action showing them near and far if possible. Another idea would be to photgraph them alongside a car's tailights with and without brake lights and signal lights to get an idea of brightness. Angle shots would laso be nice.
The Dinotte 400L and the K-Lite are bright enough that their hot spot should be aimed at the ground maybe a car lenght back and let the top of the beam only, shine in motorists faces if directly behind. The power is to get a broad fan of light bright enough to carry a fair distance. The red spot on the ground also makes the cyclist in side view. Only the Nova Bull has appreciable direct side output other than from the patch of light thrown on the ground. Superstealths can be used, maybe even facing 45 degrees forward, as they are visible in daylight at the typical distances of intersections where you want to catch a driver's attention.
Nova Bull
If you don't have a 12-16 volt lighting system, the Nova Bull will not be a cheap option. It has eight modes, no bike seat post mounting system, though it looks easily adaptable to a rear rack. At $36-40 it may be a good deal for some. It has eight modes but they were not designed with a cyclist in mind so not the best according to one cyclist in a prior thread here. It does provide some side lighting. With three of the same LEDs as the Dinotte 140R at lower curent it has a more horizontal output of about the same intensity
Dinotte 140L R
The Dinotte 140LR appears to be a single Luxeon III Red-Orange driven at 1.4 A (about 4 W) and the output is likely close to 140 lumens after lens and normal heat losses. It is $120 without battery and charger, $150 with. Same LED as in
1 What'slight but beamier. More intense and beamier than
Pe2er's.
Dinotte 400L R
Dinottte has a sale YMMV and this is likely a limited time offer so I'll state it is subject to change without notice.
The 400L red tailight with one 2-cell battery and charger is just under $200, with a 4-cell battery and charger, just over $220, and with no charger or battery but you must own a Dinotte battery and charger (customer, presumably warranty reasons with non-Dinotte batteries) just under $145. Includes seat post mount. (Now if a friend has a dinotte and you can do a battery....)
This is a two LED light. It has a 2.5 hour run time on two typical Li-Ion cells. This is about the consumption of Luxeon III Red Orange LEDs plus a driver. If that is what they are, the Luxeon II R/O are supposed to be about 190 lumens each before heat and lens losses, 380 total. They have the same thermal conductivity of 10 * C/W as the CREE XP-E Red-Orange, at 10 * C/W but with over twice the power consumption it runs hotter and will have about twice the loss in efficacy due to heat. Guessing 230-320 lumens out the back depending on temperature and how efficient the lens is and about 9.5 Watts power use. These LED's are discontinued by Phillips. Comes with a seat post mount. You can buy the headlight and tailight pair now for just under $344.
Ktronik K-Lite Battery powered tail light:
The Ktronik K-Lite battery powered kit is available in many forms at different prices (PM him). There is also a generator version. The battery version features his 20 mm ID light weight black anodized case with concentric status readout around the switch at the front (non output) end of the light or in remote switch. It uses 3 CREE XP-E Red-Orange bin ?. If it is the P2 Bin (67.2 lumen @350 mA bin), at max 700 mA, it has 1.9 X more output, or 128 lumens before losses. So 383 lumens total and 285-380 lumens depending on lens and temperature. It uses 58% as much power for 15% more light than the Dinotte 400L. If a less effective bin is used the differnece in output wil be less but the power use difference remains.
Customizing:
You can opt to use a buck puck or inexpensive 700 mA driver with or without modes and levels. A maxflex won't fit. If you use a Bflex in the K-Lite it has a 750 mA setting, not 700 mA. That will slightly overdrive the Red-Orange to about 2.4 Vf, and 6.7 more lumens each. The K-lite body looks up to handling the extra heat. The power use with Bflex at 750 mA is 6.2 watts and output is 300-400 lumens extrapolating the chart data. Half power (350 mA) is 150 lumens comparable output to the Dinotte 140LR.
You may also order a completley built light from Ktronik directly PM him.
Cutter's price for the K light kit with the Bflex is just under $190 US plus shipping. North American residents save by ordering the Bflex direct from Taskled. Going that route is about $172 plus shipping from Cutter. Exchange rates can change these prices daily. This does not include battery and charger.
DIY:
WE have the opportunity to design and build a light with side visibility like
1 what did.
http://www.candlepowerforums.com/vb/...d.php?t=264640
The LuxeonIII is dead, and the latest RedOrange LED for the task is the CREE XP-E. Three XR-E Red-Orange P2's on a triple 20 mm MCPCB and 20 mm Lens, from Cutter is currently about $30 US plus shipping to the US. Driver, wire, cable, connector, case, heat sink, solder, Arctic Alumina and other supplies, extra. Adding a Bflex brings it to about $65. A Maxflex is another $5 and will need heat sinking. These are the best but not cheapest but offer great flexibily in setting up multi level outputs.
Rice Rocket's P60 host and XP-C Drop in. The
post gives the SKU and bits. Module <$9 from DX, host $13, extension $5 at lighthound there will be other sources & prices, 2 18650 Tenergys plus charger $25-30? Aspheric lens to sand until it glows from $0 if you have one to $5 from surplushed and DX in the middle. Say $35-40 with shipping. DX says 900 lumens at 1 A. CREE says XP-C R2 Red-orange has max current of 350 mA and 56 lumens. Even on half power likely 500 mA, it is overdriven. Two flash modes where it will be
happier. It looks good close in compared to SBSF. Over 10 hour run times on 1 A constant so at least a week commuting on flash mode. But if size is as important, or more important than intensity, then two with modified bezel fitted with a say a 40 mm + aspheric might do it for about $70 sahring the charger and batteries.
Anyone want to share their ideas or plans of past, present, or future builds/mods?
PS I took so long doing this up we have other LED candiadtes and a prototype from
1 What preceding this post. Thanks Guys!:thumbsup:
