Difference between Zebralight AA flashlight models?
hazna
Australia
I lost my old zebralight AA while travelling. One of my favourite lights and now looking to replace it.
I'm confused with all the options on the website.
Whats the difference between; SC5, SC52 L2, SC53?
I'm not looking for any of the floody lights. I'd like a warm tint, but not necessarily hi-CRI (if that means a significant drop in max lumens). I also have a few 14500 sitting around, so would like something compatible with that.
gurdygurds
The 52 is only model that will accept 14500 batteries. Sc5 models will be brightest but also physically bigger. Sc53 are smaller, AA only (Eneloop recommended) and have different led options including the C version which is the warmest and also high cri. Then those models will have floody (frosted optic) and flood (mule\pure flood) options.
jon_slider
sorry for your loss,
now is your chance to upgrade.. I vote for High CRI ;-)
curious:
which model did you lose, and what types of batteries did you use?
I collected data from:
https://docs.google.com/spreadsheets/d/1WRnPsoYXE9oYKMievC1NOWQyrvSVk8HxkkEMBjAPo_s/view#gid=0
and from the Zebra website, based on what they show available, these are the choices (only one is LiIon capable):
excellent summary
the extra brightness also means batteries run down faster, and the lights are also heavier..
imo there is no advantage to LiIon in a Zebra AA, I would use Eneloop.
I would choose the SC53c because it is the one with the Highest CRI, that also has the lowest possible Low, is Neutral White (that the OP expresses interest in), and it is the smallest and lightest.
the SC5w II is the brightest, biggest, and heaviest
WalkIntoTheLight
If you think you need a 14500 for higher output, you should probably just take the leap and go for a SC64w or SC64w HI. Those are 18650 lights, and still very small. Not as small as the SC52/53 (AA lights), but more pocketable than the SC5 (a larger AA light).
As much as I like my SC5w as a very bright AA light, it's a bit too thick for pocket-carry. And I like the smaller and floodier SC52 or SC53 for indoor use.
So, I'd go with either a SC53c (for indoors) or SC64w HI (if you want to use it outdoors).
AVService
I have carried the AA ZL models since the SC52 first arrived on the scene and in my experience that model is still the best and most flexible overall really or at least it has been for me.
The SC5 is simply larger and a little tougher to carry in pocket where the smallest differences between lights is amplified by the fact that they are all so small to begin with.
This made the SC5 carry like a small brick in my pocket while the SC52 seems much smaller than any measured difference might suggest.
So a few months ago I tried making the move further upward and have beed carrying an SC64 in the same way that I did the SC52 and I have to admit that it is working out better than I feared it might.
I still like the easy any AA battery option as needed but......
The SC5 still carries like an even bigger light to me and the runtime is so much better with the SC64 that it is a no brainer for me now.
I did/do prefer the SC52 as well for the double fuel capability and would carry one with a 14500 about as much as not but in the SC64 I really get both high output AND runtime with a small compromise in size.
As for the SC53 I can not understand why they essentially mimicked the SC5 in the smaller form of the SC52 though the newer UI in the SC53 would be a perfect fit for the SC52 but it will never happen clearly either.
Hope this is a little clearer than mud now?
hazna
Australia
curious:
I had a zebralight sc50 (I think), it's probably 3-5 generations old. I used combination of nimh AA and 14500 with this light. I still have around 4-5 x 14500 sitting, which would not see much use if I weren't get another light with this capability. I also have a sc600w a few generations old .
I am amazed at the progress that has been made overtime with the zebralights... to get 500+ lumens from a AA eneloop is a pretty mean feat.
Looking at the difference in lumen outputs with high CRI and cool white are not that pronounced, so will give a high CRI light a go. (Never had high CRI but have had warm tints).
It seems like the general consensus is the sc52/3 - though lower max output are more comfortable to carry, so will focus on this range.
I do note a difference in UI between various generations, with the latest being able to set up g6/g7 levels.
There also is a difference in emitters between various models and generations?
At the moment tossing up between the sc52 L2 - which allows me to run 14500, but has older software and only seems available in cool tint
Or sc53c - which doesn't accept 14500 and has the latest software.
one has an xml2 emitter and the other XPL2 emitter. What is the difference? I'm guessing the xml is more floody than the xpl?
WalkIntoTheLight
If you want to stick to AA batteries (which has many benefits), then consider the SC5w if you plan to use it outdoors. Although it's bulkier than the SC53, it does have higher output and also significantly more throw. Because it has a larger reflector, the beam is tighter and throws nicely for outdoors. The SC53 is just too floody to see very far.
If you don't plan to use it outdoors, or only within a few meters, then the SC53c would be my choice due to its smaller size (and nicer tint).
Climb14er
Denver, CO
I prefer... options. Don't like to get hemmed in with limitations. My ZL SC 52cw is carried with 14500's and when traveling, carry an extra 14500, three Eneloops. If I need more, I buy more alkalines. With the 18650's, I carry and travel with a ZL SC62cw with one protected or unprotected cell with four extra. A very small cell charger is carried on occasion. Having either a protected or unprotected cell, choices! YMMV. I like this combination as it gives me... options.
Swedpat
Boden, Sweden
I have several Zebralight AAs. SC53c is my favorite. It has a very nice incandescent-like tint. I also have SC52d which is the earlier high CRI model. The tint is cooler though, but it's my choice if I want more throw because the smaller LED makes it the best thrower of the Zebralight AA models.
WalkIntoTheLight
That's a good point. A very small USB charger, like the Xtar MC1, is incredibly easy to carry for recharging all lithium-ion cells. I'm not aware of any NiMH charger that is so small. I usually stock my SC52's with Eneloops, but maybe your point about small chargers should make me consider 14500 when travelling.
Climb14er
Denver, CO
The Xtar MC1 is what I carry. I don't think about a small charger for the NiMH batteries/cells as mentioned, carry an extra 14500, some Eneloops and could always buy Alkalines in a pinch. That's why I like the SC52 so much. Very fine design.
Rexlion
Tulsa
Everyone should have a few Zebras. I have a herd of 4. :grin2: The SC5w actually gets the least use; between its greater size and the fact that its clip goes over the head ribs and makes it hard to pull away from whatever clothing it's clipped to, I now just leave it on my desk.
