lucca brassi
http://www.ledstyles.de/index.php?page=DownloadDBData&dataID=286 download datasheet
Hi Packhorse,Nice.
Any chance you could measure the optic.
Set it 2 meters away from a wall and measure the width of the beams spot.
According to Descartes's law, underwater this would give angles of 9° and 13° respectively.
Hi Sebastian,
Oh yes, I remember, removing the heatsink was a real pain. I removed the o-ring with a small plier (cut it before) and with the center screw pulled as hard as I could.
There is a small groove inside the body so the o-ring gets stuck in it when you try to pull. You can also try to put some oil to lubricate.
Good luck!
