I attempted to measure the standby drain of my H52Fw on a fully charged Eneloop and got alternating results of 1926 micro A and 2.6 micro A. My DMM is a Mastech MS 8268.
I've figured out the respective action sequences that cause my DMM to generate each figure.
If after completing Step 3 above, I skip to Step 6, and then test the light, the DMM still registers 1926 micro A. Therefore, there's something about testing the light with the DMM dialed to the mA range that causes the reading the change.
The light does NOT turn on when the DMM reads 1926 micro A.
What might be going on between the DMM and the light that's causing this behavior?
Thanks.
- 1926 micro A reading:
- Turn on the DMM and turn the dial to select the micro amp range.
- Place one lead on the negative end of battery and the other on the unanodized end of the tail. The DMM registers 1926 micro A.
- 2.6 micro A reading:
- Follow steps 1-2 above then...
- Remove the leads from the tail and battery.
- Turn the dial to select the mA range.
- Test the light. A reading shows on the display but quickly returns to zero.
- Turn the dial to select the micro amp range again.
- Test the light. The DMM now registers 2.6 micro A.
Thanks.
