The best way to test is to buy 20 3mm leds, solder them together in a serial/parallel configuration and test with a variable bench power supply. Then you can see if they can do the job and how much current they need for it.
When you know the amount of current for the leds, you need to look at the driver and how good efficiency you can get.
It is much easier to select batteries when you know how much power you need.
Yea i think that's the shortest and best way to see real consumpitons based on how much light i need. Have you got any suggestion on good quality, efficient leds?
Talking about batteries, are this batteries any good? (http://www.batteryspace.com/sanyo-l...7-5-aa-size-3-47wh-0-28---un-38-3-passed.aspx)
If not, are there good 14650-14500 batteries that do not cost a fortune?
