chillinn
Chillnn, if all what you want is 15-20lm on 2xAA, you could use a mag mini AA which is 19lm light. Get the NiteIze clicky tail cap, put on some Phaseburn diffusing film on the lens and you are all set for $20
Thanks for the suggestion, ma tumba. It is more than simply wanting low lumens, but also to be able to run incan the entire night. What is nicer about E series, among other things, is the lamp, which last much longer than the (on average) 4 hour AA Mini Mag lamps. Also, I think it is the reflector and lamp combination of E series that gives such a clean spill and tight hot spot. AA Mini Mags are an incredible value, and are excellent for task lighting, but I am seeking to create ambient space without having to go through 2 or 3 ~$1.50 lamps per evening.
