LED61 said:I´m feeling pretty much at ease also Lux, after seeing the 4s3p setup and the PCB board, only I think the charge rate is more like .3C give the three parallel sets.
I went back and did some research to better explain the .3C charge rate above given I am not an expert in the matter but this is what I´ve more or less found, someone correct me if I´m wrong please.
The BB has three strings of 4 in series 18650 2200 ma cells
Voltage= 4.2V x 4 cells = 16.8 Volts and Current= 2.2 amps (cells in series do not add current but voltage
Ok, so now we have three of these strings and so the charger does see an individual voltage of 16.8 V, but now we add the currents of the three strings
2.2 A x 3 = 6.6A
And hence the charge rate is more or less 0.3 C
And so that configuration allows the BB to hold a voltage for the ballast and increase the runtime. If the protection circuit built in the pack is good, it should monitor each cell connected in series and each of the three strings as well.
Yeah, that 0.3C sound more accurate now that I read your post. I don't see how it could monitor each cell in each series of 4 cells without individual cell taps though.
