Re: Aleph 2 head?
I would like some more Aleph parts too, particularly the standard tailcap. I don't find the McTC style as comfortable except with a flared body, which is also no longer available.
Once the CNC files are written, I don't see why small runs of pieces (say 50) should be so much more expensive than large runs, is it a plating batch issue with the anodizers? If so would it be more cost effective to offer the items bare? Granted I'd rather have a black tailcap than a bare one, but a bare one's better than none.
You are absolutely correct more or less.
Assuming we use the same shop a re-run is less expensive than the initial run. That is a true statement. What can impact the price is the type of shop was used. if we used a high volume shop then the larger the quantity the better the price. Unfortunately, a large volume shop could end up charging a non linear amount as the volume goes down.
On the other hand if we used a smaller shop then the smaller quantities might come out a better price and as volume increased the price might level off and not be as low as a volume shop would be.
This all assumes we would go back to the same shop as before which is probably not the case. If we don't use the same shop then we would pay the one time setup fee to program the CNC over again no matter what the quantity is.
I'm not the mechanical person here, so, this is iffy asking a EE to order metal parts.
We are looking into it and checking prices and whether the original shop is willing to run smaller runs or whether we have to source a new shop all together.
I do know the logistics is not a cut and dry simple formula. There are many factors in this equation.
Any Aleph parts that were run offshore would be a nightmare to work with them again for smaller quantities. I don't know how many times we have had to have offshore redo it to get it right and I'm in no way going down that path for smaller quantities. Even 50 pieces is not worth pulling your hair out.
That for sure means any parts that were run offshore would incur the NRE and setup at a new place locally. I know of one offhand and that would be the A3 head. It was not run here in the states. The batch that we did get some of the heads were not 6061 as they anodized differently and we ended up scrapping those.
I think the realistic focus would be going forward and any parts that have future usage regarding the GDuP or other new drivers would be the most likely candidates for replenishment if any at all.
As it stands we might restock most of everything, but, logistics, financing and risk all need to weighed out and the time/effort to manage handling the machine shop is in many cases not trivial. Questions arise, deliveries get lost, orders fall behind schedule and of course there is always the demise the parts are not to spec and the logistics to have them redo is not only time consuming, but, can add $$$ since it's possible to eat it and pay for it again.
Top that off with having to anodize them after that and you add another variable that could spell disaster if the parts after anodizer no longer fit if the build up is more than spec'd which can easily happen if the anodizers first don't strip/etch down before plating back up the net build up could make the parts a pile of scrap metal.
Wayne
