Feeler ---- AlanB softstart incan regulator
id30209
Croatia, EU
Gents, few words exchanged with Alan and he would be happy if i can collect all of your orders for him to review how to proceed. Some parts are missing and can be obtained but it will change final price as it's mentioned also in OP.
Will be updated promptly.
Regarding your desires please advise:
regulator type (standard or multilevel)
levels in percentage for multilvl (3 levels)
softstart (fast, med, slow)
ramping (fast, slow)
Temp warning (50,60,70,80,90 deg Celsius)
which bulb would you use
bulb Vmax
battery chemistry
number of cells
low batt warning voltage
Please send me PM with data filled as mentioned above.
EDIT: Let's try another option, PM's sent to everybody on the list
vestureofblood
Missouri
Hi id30209,
Thank you for sending me the PM. I am actually going to have to rescind my interest expressed in the feeler. I am very sorry about that :(
fivemega
California
regulator type multilevel
levels in percentage for multilvl (3 levels) 60%, 80$, 100%
ramping from 10 volts to 15.5 volts
(fast, slow)
EDIT: 70C is OK.
which bulb would you use: OSRAM 64623
bulb Vmax 15.5 Volt
battery chemistry IMR
number of cells 8 serial 18650
low batt warning voltage: 22 Volts
Please note:
If possible starting voltage from 10 volt then ramp up to 15.5
There is no point start from zero.
So after switched on, bulb will get 10 volts then from there ramp up to 15.5 volt.
Any voltage from zero to 10 volt is useless and won't do any good to bulb.
id30209
Croatia, EU
Here's a brief look on AlanB config file opened in Python 2.6.1. As you can ser unlike Jimmy's PhD this one uses graphical engine so configuration you like is only in 2 mouse clicks. I can send you files over email so you can try it your self. I'll post my setup soon
https://flic.kr/p/Kw6Cs2
id30209
Croatia, EU
(fast, slow)
bulb Vmax 15.5 Volt
Please note:
FM please give it a look if it's ok, temp warning is avail only up to 70deg or no regulation at all.
https://flic.kr/p/298oixU
flex76italy
Hello!
possibly interested for two regulators with Kiu socket...just let me know via PM for details!
P.S. anyone know if Carley lamps company still exist? I need high temp reflector for incan!
Thanks.
id30209
Croatia, EU
Hello!
Thanks.
Carley i belive doesn't produce these stuff but Fivemega got you covered:
http://www.candlepowerforums.com/vb/showthread.php?226585-FM3X-amp-FM3H-3-Turbo-Head-By-FiveMega
http://www.candlepowerforums.com/vb/showthread.php?232353-2-5-quot-THROW-MASTER-by-Fivemega-(2)
http://www.candlepowerforums.com/vb/showthread.php?239973-Ver2-Deep-M*g-Reflector-by-Fivemega
Will send you PM.
StudFreeman
Maine
Hey id30209,
I apologize for my tardiness. I've been undertaking a big move. I'll get you an order in ASAP!!
id30209
Croatia, EU
Just saw this thread is it too late to order 1 regulator?
Hi Crumbly,
It's still not to late cause it's moving slow due to other priorities. PM incoming.
Gentlemen i would advise to build your self with patience. There are no info WHEN it'll be done but when the time comes i'll notify you here. Quiting due to reason "i want it now" it's not nice toward Alan since this isn't his main project but side work when time allows.
KuanR
Macau S.A.R.
Put me down for 1, I have some incan parts left to build a Maglite that I abandoned due to no regulator availability
HarryN
Pleasanton (Bay Area), CA, USA
Hi, sorry to do this, but I have too many projects going right now to build up a hobby incan light.
Please give my slot to someone else.
I am sure that I will regret this when I want to build up a 24 volt based light.
Take care,
HarryN
