Fenix TK60 - 1000 lumens 3 or 4 D-cell
MichaelW
USA
I thought it was going to 4 or 5 cells (with extender).
3 alkaline D-cells isn't going to run flat regulation of high mode for very long. and I wouldn't consider running turbo on alkaline, it is just not going to happen.
Maybe Fenix thinks NiMH D-cells are the next big thing.
ScaryFatKidGT
I thought it was going to 4 or 5 cells.
It does use 4.
regulator
I guess the extension tube allows the NiMh 4 cells to give the needed voltage that 3 alkalines would. The capacity NiMh D cells is a huge plus for extended high output. This light would be a great search and rescue light.
MichaelW
USA
NiMH hold their voltage much better than alkalines under load.
Turbo mode of 800 ANSI lumens should be a 10 watt draw from the batteries. 3 or 4 alkaline D-cells just won't do.
Heck High mode of 350 ANSI lumens should be a 3 watt draw.
I'd like to know if the driver can handle the 5-C cell + PVC mod? [it would be longer, but slightly lighter] A quality alkaline C-cell should be able to sustain 0.6 watt.
kj2
The Netherlands
My local dealer says that it probably will come in the upcoming days of this month.
Price should be around €199,95
samgab
Auckland, New Zealand
Brilliant LE / cop light. As previously mentioned in this thread, given the choice between a 4D Mag (even their LED offerings) and a Fenix TK60, it's a no-brainer IMO for a nightstick/flashlight for security or LE duties. I'm looking forward to seeing a selfbuilt review of this one!
snovvman
I am only able to use flashlights with 3 cells or fewer. I'm currently using a Maglite LED 3D.
Using the TK60 with 3 NiMH cells, at 3.6 volts, is it worth it? Will I get more light from 3 alkalines at 4.5 volts? I'm guessing that the 4.5 volts will give me brighter light for a shorter time while the 3 NiMH will give me longer and more consistent, albeit dimmer, light?
If TK60 on 3 NiMH would just be bad, any recommendations for a 2-3 D size XM-L class flashlights with control on the tube?
Thank you.
Erzengel
Germany
Concerning the use of 3 NiMH cells, You should wait for the first thorough reviews. 3.6V can be enough, depending on the driver efficiency.
snovvman
Thank you. That is great advice. I will wait for the review.
