candle lamp
I can answer a couple of those questions:
As it is current controlled output, the total current draw ranges between about 4.5 and 9.5 Amperes on turbo. See the turbo chart. The draw at emitter would be split equally between the three emitters.
The level step-downs are purely voltage based, nothing to do with time or temperature.
Yes, the light uses about 30 to 36 watt on turbo, that is 10 to 12 watt for each led. This is enough to drive a XM-L led at 3 ampere (This requires 10 watt) and also have some driver looses at the higher current.
I uses a fan for cooling.
No, it is because the batteries are low in voltage.
Many thanks for the reply. samgab & HKJ! :thanks:
