I have seen the same thing on a jeep and a couple other newer cars.. I always thought it was that way from the factory.
It was not.
Why would this be illegal? Because it's too distracting??
Read post #4 in this thread.
actually in reality it is not that confusing
flashing happens fast, and only by stop lamps, and
as for what do you do when you see flashing lights in front of you?? well it is pretty simple YOU STOP.
I've seen the lights in question. The flashes happen in a span of less than a quarter of a second with the solid red kicking in
and human reflexes are on average 2/10 of a second.
It should be safe to assume
people will see the rapidly blinking lights and start to slow down, at the very least.
some cars that have factory standard brighter brake lights, it's hard to tell whether they're braking or just cruising at night. There's a compliance with the max brightness that a brake light can be, but the modern cars seem to be cranking it higher and higher when the car is just idling. (Brakes actuated on a pre-2006 vehicle will be as bright as a post 2006 model on idle). Perhaps blinking lights compensate for that difference?
There is no overlap between these intensity ranges, and just to make sure, there is also a requirement that a combination stop/rear position lamp put out 3x more light in the bright (stop) mode than in the dim (position) mode, except at certain extra-critical viewing angles where the stop light must put out 5x more light than the position light.
He's sure. What may make them look brighter (other than perhaps being slightly brighter, but still within the limits described, such as the major/minor ratio) is that the LEDs emit entirely red light, rather than having a white light bulb (and a lower-powered filament with low filament luminance) behind a red lens.Are you sure? The apparent brightness of the new tail lights (stock cadillacs and American cars) is MUCH greater than slightly older cars.
why would these things be offered aftermarket at the place of purchase?
Are you sure?
As for the blinking lights being a hindrance rather than a help, I do see point. The question is, then, why would these things be offered aftermarket at the place of purchase?
I've noticed that on new cars as well. The stock brake lights are very bright. I never had to squint from tail lights in the dark before. Just last night I jokingly put on my sunglasses when my wife also commented on it. I don't remember the car, maybe an Audi? But I've notivced this on more than one make/model. The entire interior of my Jeep glows RED!
Scheinwerfermann,
If I remember correctly, the measurement for intensity of the brake light (all lights) is only done at a single nominal temperature.
Red leds have a significant increase in efficiency at cold temperatures. Perhaps some of the perception of increased output could be related to this, I.e. cars in cold climates in winter.
Anecdotally I have noted some amber led turn signals appearing very bright on a cold night.
Semiman
any led datasheet shows about 20% difference in brighness for cold vs hot die.
and 20% loss in brighness does not look like anything dramatic, actually human eye might not even catch the difference.
i'm more inclined to think it has to do with light design. and wide range standarts.
so i doubt hot climate has anything to do with modern cars lights being bright or not so bright. i'm more inclined to think it has to do with light design. and wide range standarts.
some cars, like 06-07 accord sedan has leds in the tail, and they blind if you stop behind such car at night. i would still see all the leds and could even count them after i close my eyes, they would temp. burn in my retina, summer or winter, does not matter.
