GarageBoy
Sheesh, all you flashoholics worrying about 1/10000 Volt
Don't forget the resistors in your flashlight are at most 1%
Thanks guys! I really would only be using it for checking Lith-ion batteries, I just want a meter to be accurate for this task only. What other meters would do the job well?
Almost any meter will do, but it is niece to have a meter with 5000 or 6000 display, because you get a extra digit in the readout.
I.e. with a 2000/3000/4000 display you will get: 4.21, but a 5000/6000 display can show 4.207.
It is not that important if the precision is 0.5% or 0.05%, as long as you are checking for a max. of 4.2 volt, the small errors in the readout will only affect the number of cycles the battery can be used, not making it dangerous in any way. And as long as you do not have the specification for the actual battery chemistry, you do not know exactly what voltages to check for anyway.
Then a 4.20V measurement can range from 4.16V to 4.24V. For me, the potential that the voltage can be as high as 4.24V sucks.
Yes, there is probably a statistical distribution for the DMM accuracy, and most DMMs will not be in the error extremes. But unless you can calibrate the DMM, compare it to a known accurate DMM, or obtain a voltage reference standard, you don't know where your DMM is in that distribution.
You might not like this tolerance, but it is good enough to be safe, to get a decent number of charge cycles from the batteries and to check how much of the charge is left.
More exact measurement might be nice, but you do not really get any more useful information from it: You will not be safer, the number charge cycles depends on the exact chemistry in the battery, without knowing that, you voltage reading does not help you, and the charge left will not be more exact and even if it was, if would probably be irrelevant (Who cares if the light can run 20 or 21 minutes on the remaining charge?).
The error specification does not really work that way, the meter has to be much better calibrated from the factory. Then after being overloaded, being frozen, being boiled, etc. for a year, it must still be within tolerances.
That is the reason I believe that temperature tolerances and calibration time are important. It is very easy and cheap to make a meter that has 0.01% tolerance when leaving the factory (Thanks to microprocessors and EEPROMS), but can it keep this tolerance, that is the challenge.
If you have a accurate DMM that allows you to differentiate 4.20V from 4.24V, and you make sure that your charger goes only up to 4.20V, you will get better cycle life than if you went to 4.24V. Now you may not know exactly how many more cycles you might get because that is chemistry-dependent, but you will get more with the lower float voltage.
The error spec most certainly works the way I described for the Fluke 114.
With a 4.096V reference source, you are about as close to 4.20V as reasonably possible with an easily-obtained, commercial voltage reference. The Fluke will not use a different voltage range so any internal voltage divider circuitry issues don't apply here. Thus, whatever voltage error you measure for the 4.096V reference can be directly applied to your 4.20V measurement. If you are unconcerned about voltage measurement errors of 0.04V for Li-ion OCV, then any error using the above approach is far smaller than that.
You will also get a better cycle life if yo charge to 4.1 or 4.15 volt, it has nothing to do with the tolerances of the meter.
Have you measured some Fluke 114? I would expect them to be much better than 0.5% from factory, as I described above.
Checking the meter against a reference is a very good idea, you just has to know which one has the lowest tolerance, at least if they disagree . But that reference is only good for one voltage range (Which is enough for checking LiIon), that is very far from being enough to verify a modern multimeter. The fact that DC voltage is correct does not in any way prove that any of the other ranges are correct.
Of course the float voltage (and thus cycle life) has something to do with the accuracy of the meter. With an accurate meter, you know where you stand wrt your charger's terminating (float) voltage. With an inaccurate meter, you don't.
No I have not measured any statistically valid number of Fluke 114 samples. Have you? Regardless, you don't believe that manufactured products have a statistical distribution for their performance? I clearly said that most DMMs won't be at the extremes of the accuracy spec, which is what you seem to be saying. So what exactly is your complaint? Do you believe that all DMMs will have exactly the same accuracy out of the factory -- essentially a delta function distribution? That's still a statistical distribution.
If you have sources for higher voltage references so that other, higher DMM voltage ranges can be checked, speak up.
you do not know if a battery needs 4.20 or 4.15 volt to last 500 cycles, you only know that a lower voltage will give more cycles.
I agree that the calibration is a statistical distribution, probably a bell curve, but it does not stretch to the limit of the tolerance specifications, it is much more narrow, because much of the tolerance is needed for aging of the components.
I suspect that many cheap meters are forgetting that in their tolerances, but I have never made a study of it.
Which is what I wrote. However, I would know whether or not my charger is running to spec (e.g., 4.20V terminating voltage for LiCoO2 Li-ion) if I had a good meter.
So this is just idle speculation, despite your opinion stated as fact that the accuracy limits don't "stretch to the limit of the tolerance specifications". Got it.
You might like to know that (And I do, there is a reason that I have a Fluke 189), but it is not necessary to know when using LiIon.
It is based on my knowledge of electronic and the fact that components will change over time.
You could also check the Fluke 114 calibration manual, they require 0.125% precision on the calibrator and the meter has a microprocessor and EEPROM, i.e. it can store an exact calibration factor and is not depend on somebody turning a trimpot to "about right" value.
Who will win the Meter Wars?????
Justin Case or HKJ.
This is better than UFC.
Very good post... please would you both follow Bill's advice.Guys, your arguments are not helping here, particularly for the DMM unenlightened. It looks like point for point you can contradict each other. Why don't you continue your discussions via PM, and keep it friendly.
Bill
