RyanA
So how do the modes work now? Screw the head partway down for the outer leds, and all the way down to cycle through the modes of the Gdup with the clicky?
At the time, the LunaSol series was already "history" and I felt that posting the mod would only open a can of worms for me so put the light on the shelf and moved on...
Yep -- or as I use it, tighten it all the way and cycle through the modes, or loosen the head a bit if I need even, hotspot-less lighting.So how do the modes work now? Screw the head partway down for the outer leds, and all the way down to cycle through the modes of the Gdup with the clicky?
Ahhh, a can of McGizmo worms!! I think I'll order some! We now have the option of a warm LED..., the McGizmo worms are loose....:nana::nana::nana:
The LSC27's modes are 90, 300, and 1000mA. The LSC20's modes are 68, 225, and 750mA.Fyrstormer- I see the 750ma. drive level for high, if you don't mind sharing, what are the other two levels? Looks awesome, can't wait for a long term report...
Yes. I assume CR123 primaries would also work, as I used to own a Fenix P1D Q5 that ran this "hot" and it only worked with primaries, but I don't know what these lights' runtimes would be on primaries.Am I correct in assuming that you are using R123 Li-Ion batteries to achieve these drive levels?
Hard to believe this was six years ago. I still have the LSC27 that I used to test this mod.
