Size 15. Thanks for filling us/me in. I had attempted to fit the incompatible LOTC tail switche and since it failed I assumed (incorrectly) that the all aluminum switches did not work. Yesterday I successfully installed a z48 clunker clicky. It does work fine.
The concept of metal reinforced plastic is not new nor are glass filled polymers. None of these are new technologies. But they are good technologies. I assume the metal tube in the G2 is a dual porpose aspect of the design strength and common ground.
I can only assume that since these "plastic" parts are molded that they are less expensive to make than their aluminum counterparts.
I do have a question for you. Doesn't sending the G2L out with an aluminum head defeat the purpose of the G2 (economy)? Isn't using the plastic a cost saving measure? Throwing an aluminum head on the G2L must bump the cost of the light up quite a bit.
I have run my G2L for well over 20 minutes (with the P60L) at a time and the unit barely gets warm. Either the system is not good at moving heat or there is not much heat being generated. My P60l seems to be generating LESS heat than a stock P60 (incandescant globe) which run fine in my stock all plasic g2.
My point is Why did Surefire go to the extra expense of supplying an aluminum head when it's utility may be limited?
I like the all plastic G2.
Has anybody studied the ability of the nitrolon to move heat? What the difference is in heat generation between the LED P60L and the Incan P60? I suspect the P60 makes more heat.
In any event the G2 resally is as I said extreemely heavy duty. The Nitrolon material is very impressive. With the exception of water resistance (it may be fine for all I know but I am not ultra confident that the head will hold back much water), The G2 is a flashlight which will take years of abuse.
BTW I got a Promo G2 from the shot show CPF party from a few years ago which I will allways keep. It is unique in it's own special way.
Please forgive the use of the word plastic as I use it interchangeably with the word polymer.
Yaesumofo
Why do you doubt it?
Surefire state that their Nitrolon is a proprietary high-strength, non-conductive, impact-resistant, glass-filled polyamide nylon polymer. "Glass-filled" means that the polymer matrix has been mixed with fine
glass fibers that add rigidity, abrasion resistance, and increased stability at higher temperatures.
Whilst there are one or two TailCaps (such as the Z41 'standard' Lockout TailCap, can't think of another non-classic WeaponLight TailCap at the moment) that don't fit the Nitrolon bodies, all the Click TailCaps do.
All bezels that fit the 6P also fit the Nitrolon bodies.
Al
