march.brown
I guess that is the reason why some people buy expensive torches ... It is demeaning to be actually seen with a cheap torch ... I don't mind being demeaned (?) ... I don't have any expensive torches but I still have my immaculate (but very old) Avo Model 8 meter which still works perfectly ... I could even use it on my Li-Ions if I wanted to as the mirror scale makes it easy to read very accurately ... Checked against my five volt reference device , it is spot-on ... However it is so much easier to read my digital cheapie meters that the Avo is just left sitting on display in the study in its nice polished leather case ... The Avo 8 was a very expensive meter when it was bought for me about 37 years ago ... As I was working on electronics , I also had some Flukes for a few years ... The three Flukes all died and yet the old Avo 8 has carried on working as good as ever ... The Flukes were deemed to be beyond economic repair when in-fact it was only their display that had failed ... They had frequency measurement on them which was useful , but as I also carried a TMS and an SLMS with me that feature wasn't absolutely essential ... Luckily I wasn't paying for the Flukes ...The dollar amount here is not the important thing. There's something about using such low quality stuff that's it's almost demeaning to the user. Some low dollar stuff is OK or even quite acceptable.
My ultra cheap Harbor-Freight lookalikes are absolutely spot on in their readings of my reference and that is all I need for my Li-Ion voltage readings ... If a meter starts reading low , I check its battery and if that is not the problem I will dispose of the meter ... So far , I have given away only one meter that was 30mV out on the 20V range when measuring the 5V reference ... It was given away to my Son-in-Law 'cos it was still OK for him to check bulbs , fuses and NiMh batteries with.
So, cheap meters are OK as long as you can trust their readings ... All meters , even the most expensive should be checked against a reference that is at least ten times better (preferably more) ... Nowadays , you can have your reference checked annually for just a few dollars plus postage if you really need the ultimate accuracy.
