Can i just say a big thankyou to Setapong for the super fast delivery and kept me informed all the way.
The Heatsinks are Awsome mate and fit perfect in every way and anyone thinking of buying from Setapong won't be dissapointed in the quality of the heatsinks and the price and not forgetting his great customer service A+++ from me mate many thanks.
Any plans on making D sized heat sinks with a completely flat top to accommodate 3 LEDs + optics?
Do those flat top heatsink fokus well in a deep mag reflector, or can you offer some deeper heatsinks H22A?
Ok, after about 15 years of ownining a mag charger I have purchased my first other maglites, 3x 2D mags to mod which are totaly different to the charger (other than the Orings.)
to get to the point, I want 2 ali heatsink for xml on a 12mm board and 1 for a sst-90 with no board, so which should I consider please?
also how do I fix and adjust the heatsink for focusing and stability?
The last thing remaining to say is thanks.:thumbsup:
@H22A:
1) I have both bare and 20mm PCB mounted Cree XM-L and am after heatsinks. Which do you recommend?
2) Are your bare aluminium ones the largest size that can possibly fit into a D maglite (because i want maximum amount of metal for maximum heat dissipation)? I mean is the maximum depth utilised (does it touch the switch and on the other end the reflector?
3) Are your sinks suitable for use with both standard incandescent mag and LED mag (with deep reflector)?
4) Is the bottom recessed for a driver (need to fit a 1.3 inch h6flex driver)...if you could post pictures of undersides of your heatsinks that would be great
Thanks for your help
EDIT: 1) I have now ordered additional XM-L on 14mm PCB so will use your P7 sinks as per your previous recommendations if I decide to order; this decision i will make based on feedback to Q2,3,4 i wrote above.
Thanks!
