Hi all,
I'm designing a video light and need a bit of help with the needed battery pack.
The main trouble I find is that all battery packs already made I've find, have a from not suitable for my needs, so I'll build my own.
The idea is to build a 4 cell (18650) 2200-2800 mAh battery pack with a PCB to protect and charge the pack.
The system will have 9 XML leds 3s3p driven by a Taskled H6Flex.
I've make some fast calculations of runtime and current flowing and find out that:
So if I go to the max Iout of the driver (6.6A) I'll need a battery pack able to draw 6.6 Amp, isn't it?
Looking for cells with tabs I've find that most of them are rated 2C maximum discharge rate that means 5.4 Amp for the biggest ones.
I'm not sure if I'm understanding things well, I read a lot of articles in Battery University website and other sources of information about Li-ion cells.
If I'm not wrong, the max current I'll be able to draw form this cells is 4.4 to 5.4 Amp. Is there any way to solve that.
I'm not sure if this cells are "protected" ones and I should try to find "unprotected" ones as I'm going to use a PCB for safe balance charge and safe discharge.
Please would you be so kind to "illuminate" me?
Best regards from Zaragoza
Lumen | Watts | Current A | Time min |
3477,6 | 26,28 | 3 | 81,10 |
3780 | 29,7 | 3,3 | 71,76 |
4284 | 32,94 | 3,6 | 64,70 |
4914 | 41,85 | 4,5 | 50,92 |
5619,6 | 50,868 | 5,4 | 41,90 |
6174 | 57,24 | 6 | 37,23 |
6930 | 64,152 | 6,6 | 33,22 |
