FRITZHID
yes, both are horz, just like they would be in an auto application. when i look at the arc (using polerizing film ofcorse) i can see the arc curving upward (as if heat were drawing it) and i can see slight movement in the arc on the outer electrode. the inner electrode seems alot more stable.To be sure I understand, you see this when the light is mounted horizontally and your light is pointed horizontally? If that's the case, then the magnification aspect is the issue. I'm using the most advanced smart ballast and a universallly mountable lamp, and in full spot mode I still see an ever so slight, hardly noticeable "aurora" in the clouds around the beam center. I actually like it. It's like an alien tractor beam.
this is tru, but some flashaholics may buy my lights and i'd prefer to have answers rather then "hmmm IDK, I'll have to look into that for you". and i hate BS'n anyone so without that being normal i couldent tell someone "thats totally normal, get used to it".... is just wrong to me, unless it IS normal.those people aren't flashoholics.
thanks for the info guys, i appreciate it very much. lovecpf
