joema
HDS tests and individually calibrates every single light. However even this doesn't guarantee perfect reliability. You can always have "infant mortality" failures where the light fails early in its life....No company actually test every single product in a manufacturing run....
The OP mentioned going into an isolated, contained area by himself and was worried about flashlight reliability. In actuality you should never go into such places by yourself. There could be hazards such as toxic fumes, or inert heavy gases like Argon. In such cases you don't cough and have a chance to escape -- you die.
In the described situation a minimum of three people should be present, one on the surface and two underground. They should be in constant communication and if the people below encounter difficulty the topside person should not immediately descend to aid them. Rather he should get other help.
No flashlight is perfectly reliable, so the emphasis should be on redundancy, not on achieving perfect reliability from a single light. Each person should have at least two lights. And in the OP scenario, there are bigger things to worry about than a failed flashlight.
