modamag
oh man, it seems like your Draco is really sick pukking fire left and right. It's best to send it back so I can nurse it back to health.
modamag [b said:crewcabrob: [/b]Regarding the FluPIC, the trick is to look for the quick blink @ ~1 second after you turn it on. That blink indicate that the current mode is locked in. The next time you turn it on it will be the same state. If you turn it off before that blink the next time you turn it on will the next mode.
sideman7: same recommendation as screwabrob. If I accidentally put too much Krytox lubrication then it would feel loose. Did I buildup too much solder on the + contact of the flupic? It should only be a thin film ~ 0.005-0.010" thick.
Pumaman said:Can anyone come up with close up side-by-side pics of TICN vs ALTIN? I have seen more altin pics than ticn. I'm having real trouble choosing between these. I know modamag is super-busy, anyone else have a camera and both finishes? Its not an inexpensive investment, so I would like to be sure.
much appreciated
eltel999 said:Hi all,
I've just ordered my Draco Cree XRE
Can anyone tell me what the drive current of the flupic is set to for Burst and High?
I've search this thread but I've had no luck so far...
If it's been posted already I'd be grateful if you could point me to the post.
Many thanks,
Terry
modamag said:The max current is ~650mA mostly dependent on battery condition.
Burst = Level 10.
For the Draco FluPIC v1.0 (shipped with Luxeon) the Low setting was level 3.
For the Draco FluPIC v2.0 (shipped with Cree XRE) the Low setting was level 1 or 2.
The design of Low was to provide sufficient low light setting (5-10 lumens).
As for battery maintenance. I have mine EDC of the same two batteries (specially wrap in Polyimide tape). What I found was if you recharge regularly battery and prevent deep cycle will have a significant impact on extending your battery life.
The current drain have little affect since I use Burst Mode for < 5 minutes @ a time. For longer task such as fixing a water pipe of disassembling my PC. It put it in User Set Mode (Level 4), which actually only consumes 75% less energy.
Oh, just in case you're interested why the high lumen number for such low current level. The secret sauce is the painful LED sorting and QC during the assembly process.
