Just to be complete, here are my observations (also mostly seen in selfbuilt's great comparo with the LOD-CE).
Okay, I just got my Jet-u, and own the LF2 (cree) and used to own an LOD CE. THe LOD CE is gone so I'm going on memory only.
A few observations on the jet-u:
- Wow, that's a really wide, smooth flood. It has no throw tho and feels a bit weak due to the flood but is good for close range stuff.
- It's small and beautiful. Wish other lights could be this nice.
- The bottom is a bit narrow for tailstanding, but it does work.
- It needs a post it note on most cells to reduce battery rattle.
- It came with insanely dirty threads, but after a good clean and lube, is super smooth.
- The memory feature is pretty good. It is a benefit if you like to start on low etc. It can be a bit flakey at times, but is generally good.
- I can notice the PWM at times, but it's not bad.
- Performance on 10440 is a bit scary. Turns blue on high and heats up after 30 secs. Gets quite hot on medium too. It IS brighter of course.
I think I will try to EDC this light (using ni-mh). It's small and beautiful, feels great in the hand, and the close to low-medium range performance is quite good due to the flood.
A few notes about the competition:
- THe Fenix is a definite pocket canon. Great light and good for many CPFers. Too bad it has no low mode on 10440 and the finish is slippery and a bit thin.
- The Liteflux LF2 is great on 10440, giving a nice wall of light (at 50%) a low low, and over discharge protection. It's not a canon like the Fenix, but might be my favorite AAA light. It's also good with ni-mh but the overdischarge protection works much better with 10440s.
Hmmm, I will have to play around to see which light to EDC...
THe jetbeam is still pretty cool, but won't impress you with it's output. I like to think of it as a high tech replacement for the Arc-AAA (about the same size too!)
I'll EDC it for a little while and report back...
