nanotech17
mine is silent on low or on all levels,no noise at all.
Can it focus spot-to-flood? Any beam shots of flood?
Thanks.
mine will be up first and I have not received it yet lol.and the more I hear,makes me wonder why I bothered in the first place :shakeheadOK I bought this on an impulse, because it looked cool and the interface sounded too crazy, had to try it. I have to stop doign that!
The Good:
- Looks! I like the look of this mini light.
- Headless mode, very nice, very cool
- Tail Stand (with orange boot)
- The battery goes in Positive to head. However there are springs for the positive and negative contacts so I was not about to insert the battery without checking the manual.
- Although an OP reflector would be nice, the beam on this is light is different than many and with flood mode it really is cool to use.
The Bad:
- Only got 2 spare O-rings on a 3 o-ring light, manual shows 4.
- No Tail Stand with the black switch boot.
- Changing the boot does not give one a lot of confidence in the tail-switch mechanism, but some parts of do look OK. The switch and the plastic threaded top look suspect.
- Sometimes when on Daily-High, a press does not cycle to minimum. Never had a problem at any other level. I don't really care for daily mode all that much.
- The strobe in Daily mode is too fast.
- Possibly the switch requires too much pressure. I'll see how it breaks in.
- The price, price+shipping even worse. It is a little over priced. Should be less than $50, with a new interface.
The Ugly:
- Advanced Mode, it's the last time I'll use it. It really is as crazy as it sounds. My light came with this mode set or it was activated while putting the battery together.
- Mine has a whine on low... very anoying!
- Mode switching
Conclusion: Wait for a sale if you can. Play with one first. Hope they get a new UI before you give in and buy one.
