I don't have any 18350 on hand at the moment, so don't know if they fit. Also haven't tested any solarforce batteries, so don't know what their performance are like. I recommend you check with the experts in the battery subforum.Hello all! I'm new to the forum, just bought a jetbeam PC10 and I have at all clear that battery use.
I thought the Solarforce v2 880mAh,was a good choice (I now question of what will be worth its long longitude?)
and seen a model 700mAh AW IMR 18350 cell you know if this will be compatible with the PC10? Or has too many amps? pardon my English. thanks for your attention. regards
As for the current drain, IMR is actually rated to handle a higher power draw. But in this case, I found standard ICR chemistry (i.e. typical 3.7V Li-ion 16340 protected cells) to have acceptble runtimes, indicating reasonable power draw on the PC10. Certainly no problem to use IMR (except for the lack of protection circuts, so you have to be careful to over-draining and damaging the cells).
Again, check in with battery subforum for more info. And :welcome:
