thanks selfbuilt
RRT-15 head + RRT-21 body working with 1x18650 Li-ion
beamshot comparison RRT-21, 15, BC40 neutral (last two, 15 and BC40nw)
Yes, that is true - from my reviews (without battery installed):
RRT-21: Weight: 137.3g, Length 143.3mm, Width (bezel) 33.8mm
RRT-2: Weight 172.4g, Length 150mm, Width (bezel) 35mm
Overall dimensions are comparable, but the RRT-2 is noticeably "front-heavy" in comparison. Note that my RRT-2 is one of the first models (XR-E R2), so I'm not sure if anything has changed on the XP-G or XM-L versions.
As for build, the tailcap and clicky seem more robust to me on the original RRT-2 (but again, don't know what the currently shipping ones are like). Definitely prefer the attempt for tailstanding on the RRT-21 (doesn't really block a thumb/finger too badly, and tailstands with some wobble).
EDIT: Judging from this recent RRT-2 thread, it looks like the new RRT-2 has a very similar (though not identical) tailcap to the RRT-21. The actual switch looks identical.
It better have better build quality than the PC25 -- it costs 56% more.I just picked up RRT15 yesterday from the local dealer. Built quality is far more superior than PC25.
Don't have any to try, but if 18650 fit (as they do for the RRT21), you should be ok.Out of curiosity, have you run the RRT21 or any other broad voltage lights with 2 x IMR18350? If so, are there any issues with the batteries fitting?
As you observe, not really (unless you like lower capacity and no protection circuits ). Frankly, I don't really see the point of IMR18650 for LED lights - most multi-power lights will not be driven hard enough to benefit from IMR chemistry. The RRT-21 certainly doesn't need IMR18650 - best to stick with protected cells.Also, is there any advantage to running an IMR18650 in the RRT-21 vs. 'regular' 18650? I understand IMR's are meant for high-drain lights with less runtime as a trade-off but just curious.
Good question, I don't know. The JetBeam specs don't list an operating voltage for the circuit, and only describe support for 3xCR123A primary batteries.I just wanted to double check if the RRT-15 can be run on 3 x RCR123 batteries (despite being higher voltage than the CR123 batteries).
The difference required for RCR is substantial - you need almost 13V for RCR compared to just over 9V for CR123A (i.e. nominal RCR can exceed 4.2V each). 2x18500 is generally a safe bet in 3xCR123A lights (i.e. 9V is plenty for 2x18500).
Personally, I would be unwilling to try 3xRCR without confirmation from JetBeam (or someone who has run it without issues).
My RRT-15 arrived today.
I am glad that I opted for the extension tube, since as well as allowing the use of 2 x 18650, it also feels better balanced, compared to the non extended version with 3 x CR123's.
Should be fine. I haven't specifically tested it, but other flat-top AW cells work fine in the RRT-21. It will definitely give you the best combination of output and runtime.Do you guys think its okay to use the AW18650 3100mah protected cell for the RRT-21? Will that give me the most run time and most brightness out of this light? Will it hurt the light at all?
I have a RRT-15 on the way and would really appreciate any pics you have with the extender on it. If anyone else has extension pics, that would also be great.My RRT-15 arrived today.
