Codeman
- Joined
- Nov 26, 2004
- Messages
- 2,690
Weekly Eneloop 0.5C (1A) discharge test results:
11/15 - 1863 mAh
11/22 - 1863 mAh
11/29 - 1858 mAh (one long 6 minute run)
12/06 - 1850 mAh (1.1A?)
12/13 - 1846 mAh (1.1A)
12/13 - 1858 mAh (1.0A)
12/20 - 1873 mAh
11/15 - 1863 mAh
11/22 - 1863 mAh
12/20 - 1873 mAh
js - it just occurred to me that the reason why my capacities are lower than what you saw might be because I'm taking them right when the top-off charge has completed without allowing any time for the trickle charge. If you did allow trickle charging, then that could account for most of the differences between our discharge tests. This is one area that the Triton manual doesn't make very clear. If I understand the manual correctly, the top-off charge runs at the user-specified top-off rate for a fixed 20 minutes after the termination, after which a trickle charge is applied at a non-configurable rate based on the initial charge rate.
Assuming that you did allow time for a trickle charge, how long did you give it?
