Z
z_RBWNY
Guest
Here's my dilemma. I've only had my Klarus ST-20 for about a month. I love it... but, just recently it's been misbehaving.
Sometimes when I go to turn it on it blinks briefly and shuts off. With each subsequent click of the clickie, ALL it does is flash once. Then if I push to use it tactically, itll go on, but then when I release the button, itll STAY ON (in tactical mode!!) until I click again. Then, if I click and get it to stay on, (if the bezel is loosened for instance); as soon as I tighten it, it goes off. Alternately, if its already in tightened mode and go to increase the brightness using the bezel switch... it goes off.
Eventually, after clicking the main switch several times, or maybe holding it in once it's on, it finally operates correctly.
I can't figure out if it's the electronics, or maybe the clickie switch itself. I got it from Goinggear.com ... so if the unit is truly bad, I suppose I should contact them directly. I love the light, and would consider getting an ST10, but don't want to risk it if there are any recurring issues.
Any suggestions or similar situations with anyone else
